Zwift Ride con KICKR CORE, la bicicleta inteligente todo en uno. Por solo 1.299,99 €
Getting Started on Zwift Run
Pair Heart Rate Monitor
Adding a heart rate monitor to Zwift is one of the best ways to elevate your bike ride. Knowing your heart rate as well as your power is essential for effective training because these two measurements will help you figure out if you’re getting fitter or if you’re going too hard and should take it easy. Follow the steps below to pair your heart rate monitor with Zwift.
Follow the instructions below to pair your heart rate monitor.
  1. Log in to Zwift.
    Click or tap “Search” underneath Heart Rate on the Pairing Screen.
    Choose your HR monitor when it appears.
  2. Click “Okay.”
  3. You’re ready to go.
